STP16CPC26XTR Led driver support
Murugan K
Posted on February 13, 2018 at 12:36
Hi , I want sample code for  STP16CPC26XTR with interface STM32F103. Then how to connect more one
STP16CPC26XTR with STM32F103. Please help anyone.
Thanks & regards,
Murugan K
#stp16cpc26xtr #stm32f103
T J
Lead
Posted on February 13, 2018 at 13:42
Hi, it looks like a job for SPI... in 16bit mode.
you don't need to use the serial out, it is for cascading.to the next Driver.
you will need to use 2 output GPIOs to run the LE and /OE pins
make sure your Rext cannot go to Zero ohms, something is likely to get upset.
usually the very minimum R in series with a pot.
Andrew Neil
Posted on February 13, 2018 at 16:29
Have you looked at:
http://www.st.com/content/st_com/en/products/evaluation-tools/solution-evaluation-tools/led-and-general-lighting-solution-eval-boards/steval-ill062v1.html
EDIT
And AN3981
: LED array drivers - found on the Product Page:
http://www.st.com/en/power-management/stp16cpc26.html
