STMFlashLoader with the STM32L462RE
‎2017-12-19 4:00 PM
I'm trying to use the GUI demo STMFlashLoader with the STM32L462RE
I do to get past the initial bootloader 'detection',PID (h) 0462, BID (h) NA, Version 3.1. Then the next screen is blank, with a blank pull-down menu for device selection.
Seems like the Map file is not found
I did see the link to demo version STMFlashLoader Demo_V2.9.0RC4, no change
I also saw a comment about flow control, no change with a loop back.
Any thoughts?
#stmflashloader-with-the-stm32l462reSolved! Go to Solution.
- Labels:
STM32L4 series
‎2017-12-20 8:32 AM
You can use
STM32CubeProgrammer software for programming STM32 products.Best Regards
Imen
Imen
‎2017-12-20 6:13 AM
ST is very slow a releasing updated tools. Please up vote the parent (ie I have this problem too).
‎2017-12-20 8:32 AM
You can use
Imen
Imen
‎2017-12-28 4:07 PM
It does work via UART/bootloader thanks
Note there is a pull-down menu to select ST-LINK, UART, USB. I just tested the UART using the MCU bootloader.
For ST-LINK I use the IDE.
