STM32VL - example using interrupts in ASM
j3lda1
Posted on September 30, 2012 at 11:51
Hello, I am new in programming of STM32VL Discovery. I would like to write program in assembler for blinking LEDs using interrupts.
But it is so difficult to find examples in ASM and I can�t find some example in ASM with interrupts. Do you have some example where are used interrupts (handlers,..)?
Can you help me? Thanks a lot
#books
5 REPLIES 5
Posted on October 01, 2012 at 05:07
Do you have any experience of ARM/Thumb assembler to draw from?
In Keil, I might use the SysTick to periodically toggle LED3 thusly
SysTick_Handler PROC
EXPORT SysTick_Handler
ldr r0, =0x40011000 ; GPIOC
ldr r1, =0x200 ; Pin 9, LED3
ldr r2, [r0, #0xC] ; GPIOC->ODR
and r2, r2, r1 ; Mask bits to toggle
lsl r3, r2, #16 ; Get reset bits to high order
eor r2, r2, r1 ; Invert set in low order
orr r2, r2, r3 ; Combine
str r2, [r0, #0x10] ; GPIOC->BSRR
bx lr
ENDP
Andrew Neil
Evangelist III
Posted on October 01, 2012 at 09:10
Any particular reason why it has to be assembly, rather than, say, 'C' ?
In Assembly, you are dealing directly with the Cortex-M3 instruction set - which is defined by ARM, and not specific to ST or the STM32.
So the place to start would be the ARM technical reference site: http://infocentre.arm.com
Get yourself a copy of  ''The Definitive Guide to the ARM Cortex-M3'' by Joseph Yiu
eg,
http://www.amazon.co.uk/The-Definitive-Guide-ARM-Cortex-M3/dp/185617963X/ref=sr_1_1?ie=UTF8&qid=1349075537&sr=8-1
More ARM Books here:
http://www.keil.com/books/armbooks.asp
In the ARM 'Community' section, you will find training providers, consultants, etc:
http://www.arm.com/community/index.php
j3lda1
Posted on October 01, 2012 at 11:05
Thank you, LEDs are blinking now. I was trying to use TIM3 handler, but SYStick handler is definitely better (easier to write in ASM). I must write this in ASM because our teacher wants that. We can use ''delay'' function for blinking LEDs, but I want have better solution...
j3lda1
Posted on October 01, 2012 at 12:49
Only one thing is for me still unclear.
I used code from THE DEFINITIVE GUIDE TO THE ARM CORTEX-M3:
 LDR     R0, =0xE000E010 ; SYSTICK control and status register
 MOV     R1, #0
 STR     R1, [R0]        ; stop counter to prevent interrupt triggered accidentally
 LDR     R1, =11999999   ; trigger every 12000000 cycles
 STR     R1, [R0,#4]     ; write reload value to reload value register
 STR     R1, [R0,#8]     ; write any value tu current value
 MOV     R1, #0x7        ; enable interrupt, enable SYSTICK counter
 STR     R1, [R0]        ; start counter
Now, it´s blinking every 1 second (0,5s is shining and 0,5s isn´t shining). I thought that when I want blinking every 2 seconds, I only need set  LDR     R1, =23999999. But it´s blinking even faster! Do you know ,why?
Posted on October 01, 2012 at 13:25
Confirm what SYSCLK is, 8 MHz, 24 MHz
Check if SysTick is at SYSCLK or SYSCLK/8
The count is 24-bit, so largest value is 16777216.
Larger values give slower speeds.
