STM32L152 com0 and MCO on PA8
jantonsaad
Posted on March 25, 2015 at 06:34
Hi how are you?
I am evaluating this micro and while doing my pinout I found that MCO and LCD's COM0 share the same pin, PA8.
None of them is available in any other pin. It seems that COM0 is always needed for LCD operation.
I am taking you can't use the LCD and clock out at the same time on this part, am I correct?
If that is the case I'll need to look for a different part.
Any insight will be appreciated, thank you.
#pinout-lcd-clockout-conflict
0 REPLIES 0
