STM32L053 - internal command error when i load in keil (µvision5)
Reloadaxe
I just got my STM32L053 Nucleo64, and i'm stucked when i load on the flash memory with keil (µvision5). The error "internal command error" occured.
You can take a look at the error details.
This is my keil setup : here and here.
And this is my STM32CubeMX configuration : pinoutProject settings and code generator settings
I'm new to embedded so tell me if you need more informations. Thanks you for you time.
0 REPLIES 0
