STM32H7B3LIH6QU and DAC1_2 in conjunction with sdram (1) and usb_HS
Claydonkey
I am so close to finishing the project but have one last BIG problem.
I need DAC1 Ch2 - either exposed on PA5 or on the opamp2 vout PE7. However, the usb hs ulpi clk cannot be moved from PA5 and the D4 data line cannot be moved from PA5. Other than moving SDRAM1 to SDRAM2 are there any other solutions?
0 REPLIES 0
