stm32h750 qspi bank 2 only
JCuna.1
Can I use a external flash in qspi mode connected to qspi peripheral bank 2 ?
I wan to test 2 things:
  • Dump code from ext flash to sram partition to execute app
  • Execute in place code in ext flash
I use bank2 because in lqfp 100 package i had direct and close connection to external flash.
I believe that it can, ultimately depends on which pins you used.
Ok, so test those things.​
