STM32H743 DMA not working
‎2021-09-15 12:45 PM
In the program that transmits the value received from uart4 to uart5, I want to move the value received from uart5 to another buffer, but I move it to HardFault_Handler.
what is the reason?
And please check if the method of receiving data using the dma I implemented is the correct program.
if((RX_BUFFER4_SIZE) != __HAL_DMA_GET_COUNTER(huart4.hdmarx) ){
SCB_InvalidateDCache_by_Addr((uint32_t*)RX_BUFFER4, RX_BUFFER4_SIZE);
HAL_UART_Transmit(&huart5,RX_BUFFER4,RX_BUFFER4_SIZE-__HAL_DMA_GET_COUNTER(huart4.hdmarx),0xFFFFFFFF);
__HAL_DMA_DISABLE(huart4.hdmarx);
__HAL_DMA_SET_COUNTER(huart4.hdmarx,RX_BUFFER4_SIZE);
__HAL_DMA_ENABLE(huart4.hdmarx);
memset(RX_BUFFER4,0x00,sizeof(RX_BUFFER4));
if((RX_BUFFER5_SIZE) != __HAL_DMA_GET_COUNTER(huart5.hdmarx) ){
SCB_InvalidateDCache_by_Addr((uint32_t*)RX_BUFFER5, RX_BUFFER5_SIZE);
HAL_UART_Transmit(&huart4,RX_BUFFER5,RX_BUFFER5_SIZE-__HAL_DMA_GET_COUNTER(huart5.hdmarx),0xFF);
memcpy(RX_BUFFER_WAV,RX_BUFFER5,4096-bytesRx);
__HAL_DMA_DISABLE(huart5.hdmarx);
__HAL_DMA_SET_COUNTER(huart5.hdmarx,RX_BUFFER5_SIZE);
__HAL_DMA_ENABLE(huart5.hdmarx);
memset(RX_BUFFER5,0x00,sizeof(RX_BUFFER5));
STM32H7 Series
‎2021-09-15 1:04 PM
I don't understand the rational for the logic.
The buffers need to be properly aligned so the invalidation works properly.
The HAL_UART_Transmit()s will block.
You should be able to unpack the Hard Fault to understand, or surmise, the reason for it. You should be able to identify what the MCU doesn't like.
‎2021-09-15 1:51 PM
What do you mean by sorting buffers?
please tell me specifically
‎2021-09-15 2:15 PM
Doesn't seem like you're using the right calls. If you want to use DMA, then HAL_UART_Transmit_DMA/HAL_UART_Receive_DMA should be used.
Also possibly this:
https://community.st.com/s/article/FAQ-DMA-is-not-working-on-STM32H7-devices
‎2021-09-15 10:56 PM
yes thank you so much for your help
I changed the setting value by referring to the data you sent
However, when data is sent to uart5, it says that it receives a value in the receive buffer and then does not receive it.
Changed HAL_UART_Transmit -> HAL_UART_Transmit_DMA.
‎2021-09-16 1:40 AM
No idea what this means.
There are examples for UART DMA in the Cube repository you should get working.
