2015-12-22 04:04 AM
Hello All,
When I generate code with stm32cube for kit stm32f7discovery in filestm32f7xx_hal_conf.h is generated driver for DP83848_PHY_ADDRESS 0x01 , not for lan9742acan you help me ?Thank you2015-12-23 09:21 AM
Hi miroslav.vrba,
You can modify the stm32f7xx_hal_conf.h with LAN8742A_PHY_ADDRESS.STM32CubeMx is using the stm32f7xx_hal_conf_template.h as a template file, this is why you find DP83848_PHY_ADDRESS 0x01.-Shahrzad-
