STM32F439I-EVAL2 board support and configuring STM32CubeMX
kartik
Posted on April 15, 2014 at 19:14
I just purchased the STM32F439I-EVAL2. The board didn't come with any BSP or code that I can build in IAR. I'm guessing I need to use STM32CubeMX to configure the Bsp and setup the pinouts used on the board. Unfortunately this is fairly complicated and I would like some support on getting the bsp for this specific evaluation board. If there is a .ioc file for the evaluation board, that would be great, otherwise I would appreciate some support in setting up STM32CubeMX to generate the required code and libraries I want to use for my design.
Kartik
#cross-posted #eval #stm32f4 #stm32
Posted on April 15, 2014 at 19:54
[DEAD LINK /public/STe2ecommunities/mcu/Lists/STM32Java/Flat.aspx?RootFolder=/public/STe2ecommunities/mcu/Lists/STM32Java/STM32F439I%20Evaluation%20board%20firmware&FolderCTID=0x01200200770978C69A1141439FE559EB459D758000F9A0E3A95BA69146A17C2E80209ADC21&TopicsView=https://my.st.com/public/STe2ecommunities/mcu/Lists/STM32Java/AllItems.aspx&currentviews=10]Cross-Posted
