STM32F429 supported LCD modules
DLabi
Hi.
I got the STM32F429 eval board which comes with a small LCD and a demo on it.
I was looking into options for using a better LCD but I can't seem to find any examples with the 32F429 with a better display. Is there a list of supported/popular touch screen LCD-s that can work with it which have a better resolution and larger screen size with a relatively low cost?
And if yes, is there any sort of example code that can be used to test such displays?
waclawek.jan
I'd say, there is no such.
The STM32F439 EVAL https://www.st.com/content/st_com/en/products/evaluation-tools/product-evaluation-tools/mcu-eval-tools/stm32-mcu-eval-tools/stm32-mcu-eval-boards/stm32439i-eval.html comes with a 640 x 480 display; I'd say that except that display (and its daughterboard) and the mcu (which is only a crypto-enabled version of the '429), the boards will be identical.
You mean the STM32F429I-DISCO board? The STM32F4x9​I-EVAL can use a couple of panels.
You more generally can drive parallel RGB888 type displays, or ones with their own controller via external memory bus.​
DLabi
Yes.
I only ever got those cheap ebay/aliexpress panels, but I never looked into proper panels for making a product.
Does anyone know of some good/reliable panels that can be sourced reliably in large quantity that would work with this? Or a reliable manufacturer I could look into?
