STM32F429 StemWin
kadir ustun1
Posted on May 15, 2018 at 12:48
Hello everyone,
I try to use WM_MOTION_SetMovement function at STemWin, and I use external interrupt, but when ı use external interrupt code is not work. please help me.
this code :
WM_MOTION_SetMovement(hMotion, GUI_COORD_X, 500, 100);
GUI_Delay(500);
// _Delay(500 *2);
WM_DeleteWindow(hMotion);
WM_DeleteWindow(hDraw);
15 REPLIES 15
Posted on June 04, 2018 at 15:14
Yes , ı did. this problem is solved. But ı have another question.    I want to use two layer. but GUI_SelectLayer(1) is work but then I dont use other layer.
I think I need to configure this code. but How ? please help me ?
void LCD_X_Config(void)
uint32_t i;
LCD_LL_Init();
/* At first initialize use of multiple buffers on demand */
&sharpif (NUM_BUFFERS > 1)
for (i = 0; i < GUI_NUM_LAYERS; i++)
GUI_MULTIBUF_ConfigEx(i, NUM_BUFFERS);
&sharpendif
/* Set display driver and color conversion for 1st layer */
GUI_DEVICE_CreateAndLink(DISPLAY_DRIVER_0, COLOR_CONVERSION_0, 0, 0);
/* Set size of 1st layer */
if (LCD_GetSwapXYEx(0)) {
LCD_SetSizeEx (0, YSIZE_PHYS, XSIZE_PHYS);
LCD_SetVSizeEx(0, YSIZE_PHYS * NUM_VSCREENS, XSIZE_PHYS);
} else {
LCD_SetSizeEx (0, XSIZE_PHYS, YSIZE_PHYS);
LCD_SetVSizeEx(0, XSIZE_PHYS, YSIZE_PHYS * NUM_VSCREENS);
&sharpif (GUI_NUM_LAYERS > 1)
/* Set display driver and color conversion for 2nd layer */
GUI_DEVICE_CreateAndLink(DISPLAY_DRIVER_1, COLOR_CONVERSION_1, 0, 1);
/* Set size of 2nd layer */
if (LCD_GetSwapXYEx(1)) {
LCD_SetSizeEx (1, YSIZE_PHYS, XSIZE_PHYS);
LCD_SetVSizeEx(1, YSIZE_PHYS * NUM_VSCREENS, XSIZE_PHYS);
} else {
LCD_SetSizeEx (1, XSIZE_PHYS, YSIZE_PHYS);
LCD_SetVSizeEx(1, XSIZE_PHYS, YSIZE_PHYS * NUM_VSCREENS);
&sharpendif
/*Initialize GUI Layer structure */
layer_prop[0].address = LCD_LAYER0_FRAME_BUFFER;
layer_prop[1].address = LCD_LAYER1_FRAME_BUFFER;
&sharpendif
/* Setting up VRam address and custom functions for CopyBuffer-, CopyRect- and FillRect operations */
layer_prop[i].pColorConvAPI = (LCD_API_COLOR_CONV *)apColorConvAPI[i];
layer_prop[i].pending_buffer = -1;
/* Set VRAM address */
LCD_SetVRAMAddrEx(i, (void *)(layer_prop[i].address));
/* Remember color depth for further operations */
layer_prop[i].BytesPerPixel = LCD_GetBitsPerPixelEx(i) >> 3;
/* Set custom functions for several operations */
LCD_SetDevFunc(i, LCD_DEVFUNC_COPYBUFFER, (void(*)(void))CUSTOM_CopyBuffer);
LCD_SetDevFunc(i, LCD_DEVFUNC_COPYRECT, (void(*)(void))CUSTOM_CopyRect);
/* Filling via DMA2D does only work with 16bpp or more */
if (LCD_LL_GetPixelformat(i) <= LTDC_PIXEL_FORMAT_ARGB4444)
LCD_SetDevFunc(i, LCD_DEVFUNC_FILLRECT, (void(*)(void))CUSTOM_FillRect);
LCD_SetDevFunc(i, LCD_DEVFUNC_DRAWBMP_8BPP, (void(*)(void))BSP_LCD_DrawBitmap8bpp);
/* Set up drawing routine for 16bpp bitmap using DMA2D */
if (LCD_LL_GetPixelformat(i) == LTDC_PIXEL_FORMAT_RGB565) {
LCD_SetDevFunc(i, LCD_DEVFUNC_DRAWBMP_16BPP, (void(*)(void))BSP_LCD_DrawBitmap16bpp); /* Set up drawing routine for 16bpp bitmap using DMA2D. Makes only sense with RGB565 */
/* Set up custom color conversion using DMA2D, works only for direct color modes because of missing LUT for DMA2D destination */
GUICC_M1555I_SetCustColorConv(Color2IndexBulk_M1555IDMA2D, Index2ColorBulk_M1555IDMA2D); /* Set up custom bulk color conversion using DMA2D for ARGB1555 */
GUICC_M565_SetCustColorConv (Color2IndexBulk_M565DMA2D, Index2ColorBulk_M565DMA2D); /* Set up custom bulk color conversion using DMA2D for RGB565 */
GUICC_M4444I_SetCustColorConv(Color2IndexBulk_M4444IDMA2D, Index2ColorBulk_M4444IDMA2D); /* Set up custom bulk color conversion using DMA2D for ARGB4444 */
GUICC_M888_SetCustColorConv (Color2IndexBulk_M888DMA2D, Index2ColorBulk_M888DMA2D); /* Set up custom bulk color conversion using DMA2D for RGB888 */
GUICC_M8888I_SetCustColorConv(Color2IndexBulk_M8888IDMA2D, Index2ColorBulk_M8888IDMA2D); /* Set up custom bulk color conversion using DMA2D for ARGB8888 */
/* Set up custom alpha blending function using DMA2D */
GUI_SetFuncAlphaBlending(DMA2D_AlphaBlending); /* Set up custom alpha blending function using DMA2D */
/* Set up custom function for translating a bitmap palette into index values.
Required to load a bitmap palette into DMA2D CLUT in case of a 8bpp indexed bitmap */
GUI_SetFuncGetpPalConvTable(_LCD_GetpPalConvTable);
/* Set up a custom function for mixing up single colors using DMA2D */
GUI_SetFuncMixColors(DMA2D_MixColors);
/* Set up a custom function for mixing up arrays of colors using DMA2D */
GUI_SetFuncMixColorsBulk(LCD_MixColorsBulk);
Thank you for answered. This problem is solved.
Posted on June 04, 2018 at 15:15
uint32_t i;
LCD_LL_Init();
&sharpendif
} else {
} else {
&sharpendif
&sharpendif
Posted on June 04, 2018 at 17:19
Please, show the whole project in the attached file
Posted on June 05, 2018 at 07:38
actually ı need to setLCD_X_Config function in LCDConf_stm32f429i_disco_MB1c
But, I don't
