STM32F429 Discovery - PWM input capture
felixklemm
Posted on May 26, 2016 at 10:34
The original post was too long to process during our migration. Please click on the attachment to read the original post.
6 REPLIES 6
Walid FTITI_O
Senior II
Posted on May 26, 2016 at 18:26
Hi klemm.felix,
Share the TIMs GPIO configuration ( stm32f4xx_hal_msp.c) .  Is your application requiring to interconnect both Timers and be suychronized by RESET mode. ? because you have configured it but you didn't enabled the master TIM3
-Hannibal-
felixklemm
Posted on May 26, 2016 at 18:50 Hi Hannibal, thanks for your reply! TIM3 is only responsible for my PWM output and this output seems to be correct (checked with oscilloscope) :) Here is my MSP:
* File Name : stm32f4xx_hal_msp.c
* Description : This file provides code for the MSP Initialization
* and de-Initialization codes.
* COPYRIGHT(c) 2016 STMicroelectronics
* Redistribution and use in source and binary forms, with or without modification,
* are permitted provided that the following conditions are met:
* 1. Redistributions of source code must retain the above copyright notice,
* this list of conditions and the following disclaimer.
* 2. Redistributions in binary form must reproduce the above copyright notice,
* this list of conditions and the following disclaimer in the documentation
* and/or other materials provided with the distribution.
* 3. Neither the name of STMicroelectronics nor the names of its contributors
* may be used to endorse or promote products derived from this software
* without specific prior written permission.
* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS ''AS IS''
* AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
* IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE
* DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT HOLDER OR CONTRIBUTORS BE LIABLE
* FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL
* DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR
* SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER
* CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY,
* OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE
* OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
#include ''stm32f4xx_hal.h''
/* USER CODE BEGIN 0 */
/* USER CODE END 0 */
* Initializes the Global MSP.
void
HAL_MspInit(
void
/* USER CODE BEGIN MspInit 0 */
/* USER CODE END MspInit 0 */
HAL_NVIC_SetPriorityGrouping(NVIC_PRIORITYGROUP_4);
/* System interrupt init*/
/* MemoryManagement_IRQn interrupt configuration */
HAL_NVIC_SetPriority(MemoryManagement_IRQn, 0, 0);
/* BusFault_IRQn interrupt configuration */
HAL_NVIC_SetPriority(BusFault_IRQn, 0, 0);
/* UsageFault_IRQn interrupt configuration */
HAL_NVIC_SetPriority(UsageFault_IRQn, 0, 0);
/* DebugMonitor_IRQn interrupt configuration */
HAL_NVIC_SetPriority(DebugMonitor_IRQn, 0, 0);
/* USER CODE BEGIN MspInit 1 */
/* USER CODE END MspInit 1 */
void
HAL_TIM_Base_MspInit(TIM_HandleTypeDef* htim_base)
if
(htim_base->Instance==TIM1)
/* USER CODE BEGIN TIM1_MspInit 0 */
/* USER CODE END TIM1_MspInit 0 */
/* Peripheral clock enable */
__HAL_RCC_TIM1_CLK_ENABLE();
/**TIM1 GPIO Configuration
PE9 ------> TIM1_CH1
GPIO_InitStruct.Pin = GPIO_PIN_9;
GPIO_InitStruct.Speed = GPIO_SPEED_FREQ_HIGH;
GPIO_InitStruct.Alternate = GPIO_AF1_TIM1;
HAL_GPIO_Init(GPIOE, &GPIO_InitStruct);
/* Peripheral interrupt init */
HAL_NVIC_SetPriority(TIM1_CC_IRQn, 0, 0);
HAL_NVIC_EnableIRQ(TIM1_CC_IRQn);
/* USER CODE BEGIN TIM1_MspInit 1 */
/* USER CODE END TIM1_MspInit 1 */
void
HAL_TIM_PWM_MspInit(TIM_HandleTypeDef* htim_pwm)
if
(htim_pwm->Instance==TIM3)
/* USER CODE BEGIN TIM3_MspInit 0 */
/* USER CODE END TIM3_MspInit 0 */
__HAL_RCC_TIM3_CLK_ENABLE();
/* USER CODE BEGIN TIM3_MspInit 1 */
/* USER CODE END TIM3_MspInit 1 */
void
HAL_TIM_MspPostInit(TIM_HandleTypeDef* htim)
if
(htim->Instance==TIM3)
/* USER CODE BEGIN TIM3_MspPostInit 0 */
/* USER CODE END TIM3_MspPostInit 0 */
/**TIM3 GPIO Configuration
PA6 ------> TIM3_CH1
PA7 ------> TIM3_CH2
PB0 ------> TIM3_CH3
PB1 ------> TIM3_CH4
GPIO_InitStruct.Pin = GPIO_PIN_6|GPIO_PIN_7;
GPIO_InitStruct.Alternate = GPIO_AF2_TIM3;
GPIO_InitStruct.Pin = GPIO_PIN_0|GPIO_PIN_1;
/* USER CODE BEGIN TIM3_MspPostInit 1 */
/* USER CODE END TIM3_MspPostInit 1 */
void
HAL_TIM_Base_MspDeInit(TIM_HandleTypeDef* htim_base)
if
/* USER CODE BEGIN TIM1_MspDeInit 0 */
/* USER CODE END TIM1_MspDeInit 0 */
/* Peripheral clock disable */
__HAL_RCC_TIM1_CLK_DISABLE();
HAL_GPIO_DeInit(GPIOE, GPIO_PIN_9);
/* Peripheral interrupt DeInit*/
HAL_NVIC_DisableIRQ(TIM1_CC_IRQn);
/* USER CODE BEGIN TIM1_MspDeInit 1 */
/* USER CODE END TIM1_MspDeInit 1 */
void
HAL_TIM_PWM_MspDeInit(TIM_HandleTypeDef* htim_pwm)
if
/* USER CODE BEGIN TIM3_MspDeInit 0 */
/* USER CODE END TIM3_MspDeInit 0 */
__HAL_RCC_TIM3_CLK_DISABLE();
/* USER CODE BEGIN TIM3_MspDeInit 1 */
/* USER CODE END TIM3_MspDeInit 1 */
/* USER CODE BEGIN 1 */
/* USER CODE END 1 */
/************************ (C) COPYRIGHT STMicroelectronics *****END OF FILE****/
Thank you very much! felix
Posted on May 27, 2016 at 03:01
Period = 0, seems a bit odd
felixklemm
Posted on May 27, 2016 at 08:17
Hi clive!
Where do you read Period = 0?
Don't know what you mean.
thanks.
Posted on May 27, 2016 at 14:42
Sorry,
sConfigOC.Pulse = 0;
felixklemm
Posted on May 27, 2016 at 23:03
is only for output mode. My Problem ist that i'm getting strange values when accessing CCR1 and CCR2 when CC1 interrupt is triggered.
