STM32F407 DMA stream x FIFO control register (DMA_SxFCR) default value
Posted on July 31, 2015 at 13:38
As written in Ref.Man.
 DMA stream x FIFO control register (DMA_SxFCR) (x = 0..7)
Address offset: 0x24 + 0x24 � stream number
Reset value: 0x0000 0021
It is true only for DMA1 streams, but for DMA2 reset value is 0x0.
#dma #error
Amel NASRI
Posted on August 03, 2015 at 18:02
Hi kyb,
It seems that DMA1 clock is enabled in your case. If you enable DMA2 clock, you will see that reset value for DMA_SxFCR is 0x00000021.
-Mayla-
