stm32f407 Can't turn on led after power reset due to (calling a function _writing to flash_)
mahmuudesam
Posted on March 24, 2015 at 16:34
I wrote a very simple code to test effect of writing to flash on other lines on the code. I tested turning on the led .
It's turned on while running. But after power reset it's turned off. What may be the problem in that?
__attribute__((__section__(''.user_data''))) const uint32_t userConfig[64];
uint32_t testwritevalue=6;
HAL_StatusTypeDef status = HAL_ERROR;
void testwriteFlash(void)
HAL_StatusTypeDef status;
status = HAL_FLASH_Unlock(); // returns
HAL
_OK
FLASH_Erase_Sector(FLASH_SECTOR_2, VOLTAGE_RANGE_1);
status = HAL_FLASH_Program(TYPEPROGRAM_HALFWORD, (uint32_t) userConfig, (uint64_t)testwritevalue);
// returns
HAL
_OK
status = HAL_FLASH_Lock();
// returns
HAL
_OK
int main(void)
HAL_Init(); // initialization
SystemClock_Config();
// initialization
MX_GPIO_Init();
// initialization
HAL_GPIO_WritePin(GPIOB,GPIO_PIN_10,0);
// turn on the yellow led
testwriteFlash();
while (1)
Thanks in advance
5 REPLIES 5
Posted on March 24, 2015 at 17:41
How large is your total code/image footprint? See .MAP, linker output, etc.
Is your board really powered at 1.8V - 2.1V?
Is BOOT0 Low?
mahmuudesam
Posted on March 24, 2015 at 18:05
About the power it's powered at 3.3V and I tried all voltage ranges 1,2,3 with the same problem
BOOT0 is connected to GND through a (12.4K  resistor)
About the code size
text       data        bss        dec        hex        filename
     8933      384        456       9773      262d     test_flash_24_3_2015.elf
About the .map file, it contains the following
Memory Configuration
Name                       Origin                              Length             Attributes
FLASH1         0x0000000008000000 0x0000000000008000      xr
DATA             0x0000000008008000 0x0000000000004000     xrw
FLASH           0x000000000800c000 0x0000000000074000     xr
this is the part of the linker for the user configured flash
MEMORY
// RAM
default
  FLASH1 (rx) : ORIGIN = 0x08000000, LENGTH = 32k
  DATA (xrw) : ORIGIN = 0x08008000, LENGTH = 16k
  FLASH (rx) : ORIGIN = 0x0800C000, LENGTH = 512K-48k
//others default
SECTIONS
    .user_data :
      . = ALIGN(4);
         *(.user_data)
      . = ALIGN(4);
    } > DATA
jagdishk741
Posted on March 24, 2015 at 18:30
Hi Clive,
I'm trying to interface my GPS board (SKG13C) with STM32F407 using usart as part of my project. The result should be in NMEA format. Is there any code available?
I'm not that good with coding, but I can understand the code upto some extent.
Cn u help me out.,?
Posted on March 24, 2015 at 19:44
Cn u help me out.,?
Wildly off-topic, I posted a worked NMEA parsing example in [DEAD LINK /public/STe2ecommunities/mcu/Lists/cortex_mx_stm32/Flat.aspx?RootFolder=/public/STe2ecommunities/mcu/Lists/cortex_mx_stm32/Issue%20with%20USART%20RX%20buffer%20and%20char%20filter&FolderCTID=0x01200200770978C69A1141439FE559EB459D7580009C4E14902C3CDE46A77F0FFD06506F5B&currentviews=127]this thread.
Posted on March 24, 2015 at 19:46
So not a size thing, as I suggested before it's import to code in a way that receives the status from the routines, and doesn't proceed doing things if the prior step failed.
Get a serial port on your board so you can output actionable diagnostic information.
