STM32F4 HAL CAN Receive Interrupt Error
I'm trying to get the STM32F4 Discovery board to transmit and receive CAN frames.
I've already got it to work with polling, now I'm trying to get the transmit and receive interrupts working.
The transmit interrupt works flawlessly, however, the receive interrupt isn't working.
Everytime I try to send a can frame to the STM32F4, it freezes in the
HAL_CAN_RxCpltCallback function, leaving the led on.
Here is the code:
CAN configuration and interrupts priority:
void
HAL_CAN_MspInit(CAN_HandleTypeDef
* hcan){
GPIO_InitTypeDef
GPIO_InitStruct;
if
(hcan->Instance
==CAN1){
/* USER CODE BEGIN CAN1_MspInit 0 */
/* USER CODE END CAN1_MspInit 0 */
/* Peripheral clock enable */
__HAL_RCC_CAN1_CLK_ENABLE();
/**CAN1 GPIO Configuration
PB8 ------> CAN1_RX
PB9 ------> CAN1_TX
GPIO_InitStruct.
Pin
= GPIO_PIN_8|GPIO_PIN_9;GPIO_InitStruct.
Mode
= GPIO_MODE_AF_PP;GPIO_InitStruct.
Pull
= GPIO_NOPULL;GPIO_InitStruct.
Speed
= GPIO_SPEED_FREQ_VERY_HIGH;GPIO_InitStruct.
Alternate
= GPIO_AF9_CAN1;HAL_GPIO_Init(GPIOB, &GPIO_InitStruct);
/* Peripheral interrupt
init
*/HAL_NVIC_SetPriority(
CAN1_TX_IRQn
, 0, 2);HAL_NVIC_EnableIRQ(
CAN1_TX_IRQn
);HAL_NVIC_SetPriority(
CAN1_RX0_IRQn
, 0, 0);HAL_NVIC_EnableIRQ(
CAN1_RX0_IRQn
);/* USER CODE BEGIN CAN1_MspInit 1 */
/* USER CODE END CAN1_MspInit 1 */
main function:
MX_GPIO_Init();
static
CanTxMsgTypeDef
TxMessage1;
static
CanRxMsgTypeDef
RxMessage1;/*##-1- Configure the CAN peripheral #######################################*/CanHandle1.
Instance
= CAN1;CanHandle1.
pTxMsg
= &TxMessage1;CanHandle1.
pRxMsg
= &RxMessage1;CAN_FilterConfTypeDef
sFilterConfig1;
CanHandle1.
Init
.TTCM
=DISABLE
;CanHandle1.
Init
.ABOM
=DISABLE
;CanHandle1.
Init
.AWUM
=DISABLE
;CanHandle1.
Init
.NART
=DISABLE
;CanHandle1.
Init
.RFLM
=DISABLE
;CanHandle1.
Init
.TXFP
=DISABLE
;CanHandle1.
Init
.Mode
= CAN_MODE_NORMAL;CanHandle1.
Init
.SJW
= CAN_SJW_3TQ;CanHandle1.
Init
.BS1
= CAN_BS1_4TQ;CanHandle1.
Init
.BS2
= CAN_BS2_3TQ;CanHandle1.
Init
.Prescaler
= 4;
if
(HAL_CAN_Init(&CanHandle1) !=HAL_OK
/* Initialization Error */
Error_Handler();
/*##-2- Configure the CAN Filter ###########################################*/
sFilterConfig1.
FilterNumber
= 1;sFilterConfig1.
FilterMode
= CAN_FILTERMODE_IDMASK;sFilterConfig1.
FilterScale
= CAN_FILTERSCALE_32BIT;sFilterConfig1.
FilterIdHigh
= 0x0000;sFilterConfig1.
FilterIdLow
FilterMaskIdHigh
FilterMaskIdLow
FilterFIFOAssignment
= 0;sFilterConfig1.
FilterActivation
= 1;sFilterConfig1.
BankNumber
= 0;
if
(HAL_CAN_ConfigFilter(&CanHandle1, &sFilterConfig1) !=HAL_OK
Error_Handler();
if
(HAL_CAN_Receive_IT(&CanHandle1, CAN_FIFO0) !=HAL_OK
Error_Handler();
i=0;
// Infinite loop
while
(1){
if
(HAL_CAN_Transmit_IT(&CanHandle1) !=HAL_OK
/* Transmission Error */
Error_Handler();
HAL_Delay(200);
Receive interrupt callback:
void
HAL_CAN_RxCpltCallback(CAN_HandleTypeDef
* CanHandle){HAL_GPIO_WritePin(GPIOD, GPIO_PIN_15,
GPIO_PIN_SET
);HAL_Delay(30);
GPIO_PIN_RESET
Transmit nterrupt callback:
void
HAL_CAN_TxCpltCallback(CAN_HandleTypeDef
* CanHandle){HAL_GPIO_WritePin(GPIOD, GPIO_PIN_14,
GPIO_PIN_SET
);HAL_Delay(30);
GPIO_PIN_RESET
