STM32F4-Discovery 5V pwm
selmesal
Posted on August 17, 2016 at 20:06
I currently have a 3.3V PWM on TIM3_Channel2.
Can the output be changed to a 5V logic?
Sel
Posted on August 17, 2016 at 20:43
It depends on what you are driving.
You should probably consider using a buffer that can do the level conversion.
You can configure the pin in open-drain mode, and have a pull-up resistor to 5V on pins that are FT (Five volt Tolerant) per data sheet.
