2025-09-10 3:17 AM
Hi team.
We have been using the STM32F373VCT6 microcontroller across three different projects for the past three years. However, during testing and debugging time we’ve encountered a recurring issue where the controller is getting short between the 3.3V supply and ground suddenly. This problem has occurred multiple times and is affecting our development process. We kindly request your support in identifying the root cause of this problem.
2025-09-10 4:07 AM
You're going to need to give a lot more detail for people to be able to help you with that!
Please see: How to write your question to maximize your chances to find a solution
2025-09-10 4:29 AM
And tell us what you had connected to those boards, especially peripherals with supply voltages of 5V and higher, and those related to inductive loads (like motors or voltage converters).
I have STM32 boards that or more than 10 years old, used frequently, and which still work fine.
