STM32F303x - Hardware Resets
‎2015-02-09 6:51 AM
What is the usual procedure for power-on reset for other chips besides the MCU? Is there a reset_out signal or method coming from the MCU that is recommended? Or is there a method for resetting all chips in a system including the MCU?
#reset-stm32- Mark as New
‎2015-02-09 7:54 AM
‎2015-02-09 8:11 AM
See Fig.11 ''Simplified diagram of the reset circuit'' in RM0316. Unfortunately, the diagram in datasheet and related timing data do not reflect the bidirectional character of the pin. JW- Mark as New
‎2015-02-09 8:13 AM
But if I just pull NRST low and then high that should do for the MCU reset?
‎2015-02-09 8:47 AM
The NRST/NRESET pin in ARM designs is generally considered as bi-directional. You can reset the CPU and all the peripherals (internal/external), both with external reset circuit(s) and by the processor (core via NVIC). Some of the causes can also be read from a register post reset.
You can supply your own power-on-reset circuits, including ones that monitor multiple supplies, and ensure sequencing, thresholding, etc. The one thing you must be very careful of is not to drive NRESET high with a push-pull driver, this will prevent the part from correctly resetting.Up vote any posts that you find helpful, it shows what's working..
‎2015-02-10 9:15 AM
Big thanks for that! I just changed the supervisor reset from PP to OC...- Mark as New
‎2015-02-10 9:32 AM
You're not the first one to have done that, it's a big trap and lots of people fall in it.Up vote any posts that you find helpful, it shows what's working..
