STM32F303vc discovery import BSP library in IAR
Options
2018-01-21 10:54 AM
Posted on January 21, 2018 at 19:54
I have some problems with import the BSP library in IAR Workbench. I'm using stm32f303vc discovery board and i want to use the gyroscope and accelerometer installed on the board. I also followed this guide (
https://community.st.com/docs/DOC-1500-how-to-add-a-bsp-on-top-of-cubemx-421-generated-
) for import the library but i have always a problem. When i recall the function to init the gyroscope or accelerometer (example: GYRO_IO_Init();) , IAR give me this messages: Error[Li005]: no definition for 'GYRO_IO_Init' [referenced from C:\Users\xxx\Desktop\example\EWARM\example\Obj\l3gd20.o] and other similar messagges. Can you help me please?
0 REPLIES 0
