STM32F302R8T6 minimal circuit Help
engineering23
Posted on November 02, 2015 at 04:06
I am very new to ST microcontrollers and wanted to know if someone can help me with a schematic for the STM32F302R8T6. The hardware I am designing is a USB to CANBUS tool but I need to know whats the minimal circuit needed to run this microcontroller at 72mhz. Below are a few parts I would like to use. See attached schematic.
5v to 3.3v regulator - TCR2EF33,LM(CT
crystal - ABS25-32.768KHZ-6-T
can transceiver - MCP2551-I/SN
Any help would be great
Amel NASRI
Posted on November 09, 2015 at 17:07
Hi Marc,
In order to validate your schematic, I suggest you have a look to the recommendations provided in
http://www.st.com/st-web-ui/static/active/en/resource/technical/document/application_note/DM00070391.pdf
-Mayla-
