STM32F103C8 with Watchdog Timer
Sudhakar.R
i try to crash my code to check the watchdog timer is reseting the code or not. for crashing my code i use timer interrupt. i.e
TIM2_IRQHandler()
TIM_IRQHandler() instead of TIM2_IRQHandler . so, code will be crash at that time watchdog timer should reset the my code.
how to enable the watchdog timer.
Pierre_Paris
Hello @Sudhakar.R,
Thank you for your question.
The watchdog timer explanation on how to enable and configure it is available in this article named "getting started with WDG".
Best Regards,
Pierre
