2009-12-09 09:26 PM
STM32F101-Global interrupt enable/disable
2011-05-17 04:05 AM
Hi
I want to have control on global interrupt,but I couldnt find any register for it,what I want is to have a control to disable all of the interrupts at the same time using one cycle instruction.Will appreciate for your help2011-05-17 04:05 AM
Hi bozorgzad,
Refer to this FAQ : http://www.st.com/stonline/faq/faqview.php?ids=1246 Cheers, STOne-32. [ This message was edited by: STOne-32 on 09-03-2009 18:36 ]2011-05-17 04:05 AM
Nowadays with 3.x version of the library the functions are defined in core_cm3.h and are named:
__disable_irq(); __enable_irq(); Short info about the functionality can be found in CMSIS_Core.htm document (provided with the library). More info on page 18-19 in the PM0056 doc. (15491.pdf manual april 2009 version). Best regards, Per
