STM32F051 - Question regarding external / internal oscillator
‎2016-02-22 3:27 AM
I have bread boarded STM32F051 and it's working. The clock is configured for external 8Mhz Crystal. Its working checked with scope. When i remove the crystal it seems to still work from internal oscillator. I would like switchover to be disabled. how can i do it. using std peripheral lib. Thanks, Jai.- Mark as New
‎2016-02-22 5:39 AM
The processor always starts off the internal clock, you get to enable the external one and the PLL within the code under SystemInit(), where you get to choose what happens.
‎2016-02-23 12:29 AM
‎2016-02-23 3:43 AM
dear kumar.jai.001,
First try to enable HSE if it fails then disable HSI by following piece of code-RCC_HSICmd(DISABLE);/*Please
mark helpfull
if this post helps you or solves your problem.*/
/* If you need any personal support for your work please contact at
embeddeddesign.help@gmail.com*/
‎2016-02-23 12:19 PM
From a software-point-of-view, I don't like editing those files: They are delivered to me, and whomever made them may have an update later on which I'll have to merge with my changes if I edit the file.
The system_stm32fxxx.c are supposed to be board/implementation specific, in your project directory, you are supposed to ''own'' them.Up vote any posts that you find helpful, it shows what's working..
‎2016-02-23 1:48 PM
‎2016-02-23 5:03 PM
Ok, but I don't think the code should be considered golden, it is a minimal template with the expectation that someone using it actually understands it and refines it.
