Prajnyajit
STM32F030F4P6
  • June 11, 2022
  • 1563 views
When I am uploading a program via Arduino IDE, it is giving me an error as " arm-none-eabi/9.2.1/../../../../arm-none-eabi/bin/ld.exe: region `FLASH' overflowed by 18724 bytes
and " exit status 1
Error compiling for board Generic STM32F0 series."
Please tell me how to upload the program successfully in STM32F030F4P6 using Arduino IDE.
waclawek.jan
Your program is probably too big to fit into the STM32 of your choice.
Try to change the optimization level of compiler. I don't know how to do that in Arduino IDE, I don't use it. There are probably not many users in this forum using Arduino, so you may want to ask in some Arduino-specific forums, maybe https://www.stm32duino.com/
Tesla DeLorean
Guru
June 11, 2022
The STM32030F4P6 only has 16 KB of FLASH, which is not a lot to do much of anything with, and what you're trying cram in there is already 2.15x the capacity.
Things like floating point can eat a lot of space immediately, and there's not much space to amortize that cost over from your application, ie large buy-in cost, unbalance percentage of available space.
There are half a dozen RP2040 based Arduino/mBedOS boards that might be significantly better suited. The generic ones start with 16Mb/2MB QSPI FLASH, and extend out to ones with 128Mb/16MB
