STM32F0 - SPIRIT1
michelemancini2
Posted on January 18, 2013 at 17:03
Hi, I work with STM32F0, I connect this to SPIRIT1.
I need assistance
of ST, because I have difficult to work spirit1.
I read and write register of SPIRIT1 with
successfully
I use the library of ST for work with spirit1,
but I can not
set
the
spirit1
to transmit and receive
How can I get
a
assistance
I
tried but
nothing!
There is a section
of
the
forum
dedicated
to
spirit1
Michele Mancini
5 REPLIES 5
Posted on January 18, 2013 at 19:55
The normal support path would be to contact the FAE (Field App Engineer) with your distributor or ST. They may also be able to point you at a contractor/consultant who many be able to provide you with assistive services.
Andrew Neil
Posted on January 19, 2013 at 14:50
''I need assistance
of  ST''
As clive1 says, ST do not provide support via the forum - it's just user-user discussion
''There is a section
of
the
forum
dedicated
to
spirit1
Probably not.
Not only do ST not provide support via the forums - they don't even provide a complete set of forums!
/be013a9c
/dba6d774
etc...
petrvanecek
Posted on April 06, 2014 at 09:28
Hi could you tell me where I downloaded the library for spirit1. Please send me a link
Thanks Petr
Posted on April 06, 2014 at 18:51
It's been my general experience that documentation and software related to radio products is often provided under NDA. If you have a technical inquiry related to ST products, and can't find the materials you need with a Bing/Google search then you need to make contact with ST sales and support locally through classic channels, and not by posting to public user support forums.
http://www.st.com/web/en/catalog/tools/PF258102
Andrew Neil
Posted on April 06, 2014 at 21:06
If you have one of these:
The download link is printed on the card.
If you have another demo/evaluation kit, it should tell you where to obtain the associated supporting materials (which, as already noted, may well require that you contact your FAE/distibutor/whatever).
If you don't have any kit,  Get (at least)  One!
