2015-06-11 9:49 AM
It appears as though the PHY driver generated by STM32CubeMX is just for TI's dp83848c? I'm going to modify the driver the LAN8710A PHY, but it would be nice if Cube supported choosing different PHYs (i.e. different register maps for the extended/vendor specific registers). thanks, Paul2015-12-30 9:47 AM
Hello Paul,
could you share the modification you made with us? I am about to use the same PHY.
Best regards,
Jeroen
