STM32CubeMX 4.9.0 and write protected .ioc
hbarta2
Posted on July 21, 2015 at 17:47
Gee whiz! how about popping up an error message if the .ioc file is write protected and the user hits save and then exits!
Crap. Good thing my changes were not extensive but highly irritating nonetheless.
just4you
Posted on July 23, 2015 at 14:41
Maybe the authority problem.
The easy solution is copy the specific folder under the Program Files\.....\xxx\xxx to other authority free folder.
Posted on July 23, 2015 at 15:19
You totally miss the point.
A considered user interface would a) indicate a file is read-only, and not permit edits, or b) catch the write failure, and prompt for a ''Save As'' alternative, or push back into the application so this could be done.
