STM32Cube with Eclipse Kepler
jappelino
Posted on June 02, 2014 at 10:43
I downloaded the Eclipse plugin but I am having trouble running it: ''java.lang.NullPointerException''
I am running the Kepler Service Release 2
Build id: 20140224-0627
Should it be possible or do I have to change to one of the suggested versions?
martingingras9
Posted on June 02, 2014 at 17:22
Try changing java version.  I am running 1.7.0 and I was having the same issue with the latest java version.
I am still unable to get a damm HAL based hello world to compile and run properly....
