2016-03-30 6:01 AM
Hi all,
I have been working with ST for many years but the Cube software might make me move to a different brand! The Cube might be nice for newbies but it is a PAIN for people like me who need to push the micro's to their limits.So please ST, give me back the std_peripheral!2016-03-30 6:17 AM
From your lips to ST's ears !
But honestly, I got the impression that the Cube project is held up by higher, non-technical management decision, despite the obvious divergence between advertisement and reality. And thus it won't go away that easily ... You can try to create you own library, though, if the notorious register-banging is no option ...2016-03-30 6:27 AM
The best choise, don't use any library ;). Like many profesionalist.
2016-03-30 6:47 AM
Hi
The STM32Cube is a new approach for STM32 libraries offering HAL functions which are hardware independent. So you may use the same prototype for almost all products.The STM32Cube comes with the
tool which is a initialization code generator. Please refer to
http://www.st.com/st-web-ui/static/active/en/resource/technical/document/user_manual/DM00104712.pdf
for more details on how to use it.You still be able to use standard libraries and still exist new release published in our website. You need just to have new standard library release downloaded locally.
For any help regarding STM32Cube or Standard library, please submit your request on the forum ''
[DEAD LINK /public/STe2ecommunities/mcu/Lists/STM32Java/AllItems.aspx]STM32 Software Tools and Firmware''.
-Hannibal-2016-04-12 3:12 AM
Hi Hannibal,
We have many projects, all based on STD_PERIPH. We cannot afford to rewrite all of our low level stuff. You mentioned a locally download of the std_periph for the STM32F7, that sounds good but where can I download from???2016-04-12 8:25 AM
Hi ramakers.andre,
For the new families like STM32F7, only STM32Cube Hal Library is taken into account. A low layer drivers will be released soon to replace standard library directives and give more flexibility to users. Till that day, I invite you to try usinghttp://www.st.com/web/en/catalog/tools/PF259242
which helps you to build and generate your initialization code and customize then your project as you want by adding your own code. You can get inspired from a several example in thehttp://www.st.com/web/catalog/tools/FM147/CL1794/SC961/SS1743/LN1897/PF261909
. Many users migrate like that and are satisfied. -Hannibal-2016-07-07 7:51 AM
Hi Hannibal,
We are now 6 months later, is the promised library available now? I still can't find it.In between time I have created my own std_periph files for the STM32F7.Best regards,André2016-07-08 2:57 AM
IMHO the right decision. Having had a closer look at the Cube stuff myself for a F7 board, I quickly turned away. Not only because of the great number of bugs, but even more by the awkward design patterns that Cube enforces on applications.
2016-11-04 3:08 AM
It seems I have made the right choice by making my own stdperiph library because there is still no reaction. At least with my own files I can make the little fellow run like hell :)Regards,2017-06-27 2:01 AM
Hi all,
We are 1 year
later, ST promissed to release new low level drivers different from the Cube stuff. So where are they? I still can't find them on the site. Luckily I wrote the stdperiph files for the STM32F7 myself, otherwise I would have lost loads of performance.How about letting ST know your thoughts on this issue? Please comment/vote
Thanks,
André
