STM32 f4 + Bluetooth
Options
‎2013-06-06 9:23 PM
Posted on June 07, 2013 at 06:23
I must establish a data transfer between a temperature's sensor connected with Bluetooth Bee and STM32 F4 with a Bluetooth Bee too.The connection between the sensor and the PC is set correctly (COM port) on the problem is how to establish the connection between the sensor and the STM32 card via Bluetooth without user intervention .You will find attached a schema explaining my problem.PS: I want to take the measures from the sensor to the PC through the STM32
2 REPLIES 2
Options
‎2013-06-07 8:10 AM
Posted on June 07, 2013 at 17:10
What's stopping you from developing your own solution?
If you need technical expertise, ST maintains a list of consultants/contractors.
Options
‎2014-01-03 8:02 AM
Posted on January 03, 2014 at 17:02
Have a look at This 32feet.com or is it 32feet.net They have api that could meet your need
In any case it should be helpfull
