stack use monitor
‎2011-08-03 6:06 AM
I'd like to add stack usage monitoring to my application. I can't afford the overhead of stack checking on every function call, so I was considering adding a routine that runs periodically to monitor the stack high-water mark. I'm not using an RTOS.
I know my stack size, but how do I find the beginning of the stack? will it always start at the same place? I'm using the Keil tools, if that makes a difference. Thanks!- Mark as New
‎2011-08-03 8:41 AM
The stack is set by the first vector on the STM32, and descends from there. The C startup code may also place it too, before calling main().
A 4K stack, on a 20K part, can nominally get placed at 0x20005000 and descend to 0x20004000. Fill that space with a distinctive pattern, and enumerate upward to measure the depth used. In Keil the bottom of the stack is defined by Stack_Mem, and the top/start as __initial_sp My stack checker loads a pointer to Stack_Mem, and the climbs 32-bits at a time until if find the bottom of the used stack, and then computes the amount used based on the known size.Up vote any posts that you find helpful, it shows what's working..
‎2011-08-03 12:04 PM
Thank you; conceptually I understand what to do, but I'm getting stuck on the implementation, perhaps because I'm new to the Keil/ARM tools. Now that you've steered me towards the appropriate linker symbols, I can't seem to reference them (__initial_sp and Stack_Mem) from my C code; the linker complains the symbols are undefined. I tried declaring them as extern but it didn't help.
‎2011-08-03 4:05 PM
In stm32F10x.s (startup.s, whatever)
EXPORT Stack_Size EXPORT Stack_Mem Stack_Size EQU 0x00001000 AREA STACK, NOINIT, READWRITE, ALIGN=3 Stack_Mem SPACE Stack_Size __initial_sp in C application extern void * Stack_Mem; unsigned long *p = (unsigned long *)&Stack_Mem;Up vote any posts that you find helpful, it shows what's working..
‎2011-08-04 8:18 AM
I was missing the EXPORT statements; it works now.
Thanks!
