STA8088FG
Options
‎2013-06-05 11:30 AM
Posted on June 05, 2013 at 20:30
Hi
I have a question about STA8088FG but no place in forum for it The documentation is so thin I dont know what is required to program it is it already programmed? how to use it? does it output formated nmea? what are the command set? Thanks
Options
‎2013-06-05 12:21 PM
Posted on June 05, 2013 at 21:21
Assume you won't, this is a part for commercial clients likely to be spending several million dollars on parts (ie Apple, Nokia, Garmin, etc). If this describes you, contact your local ST rep. A better question is who is using this part in their modules
Options
‎2013-06-06 4:53 AM
Posted on June 06, 2013 at 13:53
Hummm I see
I don't have millions of dollar to spend, but I would like to make a board out of it :) Ill ask my rep Thank you
