ST-Link won't run stand-alone on Windows 7
petecarr
Posted on October 28, 2013 at 04:24
I was interested in trying Espruino software on an STM32F4 and downloaded ST-Link.
Unfortunately, when I try to run STM32 ST-Link Utility.exe I get a dialog
''This application was unable to start correctly ()xc000007b). Click OK to close the application.''
Am I invoking it correctly? Or is there some sort of setup I need to do before starting up?
The IAR embedded workbench seems to have no problem dow loading to this board.
1 REPLY 1
Posted on October 28, 2013 at 14:38
Hard to say, running fine here, stand-alone and with Keil. Mostly on Win7 64-bit machines running pro and ultimate.
Check you have current drivers/firmware/utilities.
Check you have appropriate 32/64-bit drivers.
Check that IAR isn't currently using/connected to the ST-LINK
Check you have administrative rights, no issues with USB attachment or Anti-Virus, or Daemon Tools.
