spi1 work well only in debug mode
Posted on January 22, 2014 at 09:41
i am trying to communicate between stm32100rb discovery value and transceiver cc2500 via spi1. for checking, i wrote a value to the cc2500 to specific register, and then, i read the value of this register, and print it.
when i use the debug, it work well, and give me the right value.(even when it in debug mode only, and i press the reset button, it also work well, although i don't running it with the debug application).when i download the same code, and running it without turn on the debug, it print me wrong value( like 'f' or '0', instead of '29' in my case)i will be happy for some advice.. thank you!
