Shutting Down PWM Outputs At A Breakpoint
tsutera
Posted on April 06, 2010 at 17:32
swhite2
Posted on May 17, 2011 at 13:46
If you're using the ST Standard Peripheral Library take a look at the DBGMCU_Config() function. That can be used to stop timers when the core is halted which may or may not be what you wan.
