Should the input of function "GetSectorSize" not be the sector number and not the address as in the flash example in the ST32F4?
tech2399
Couldn't you just test the thing using printf?
Size by address would be generally more helpful.​
tech2399
Have a look at the examples and you'll see. I changed the function and added ADDR_ to FLASH_SECTOR_xx to keep the input. Doesn't work otherwise.
Maybe change in next release.
