SDIO and SD fat access example?
natblist
Posted on February 09, 2012 at 01:06
Hi Chaps,
Going slowly mad trying to get Chan Fat working with the sdio libs on a stm32f4.
I'm using the most recent (1.0.0) library for the F4, and the low level access demo within that library builds and (at least appears to ) work OK.
I've spent many, many hours attempting to patch in 0.9 version of fatfs from chan (thks chan, you're a hero) - but I can't get it to work.
If possible, I'd really really appreciate a demo project/source (or direction to - though I've scoured the web and can't find anything that works!)
I'll post separately about the current problems I'm having with the my current build, but a working example would sort it.
Many thanks,
nat.
#hse-sdio-stm32 #stm32-fat-chanfat-fatfs-sdio #sdcard-stm32f4-sdio-fatfs #sdcard-stm32f4-sdio-fatfs
84 REPLIES 84
cleonb322
Posted on September 19, 2016 at 22:52
If I closed a file and then reopen it, I cannot write more data to it after reopening it, but if i keep it open i can write as many lines as i want then close it after i am finished writing. Does anyone have a similar issue withe ELM Chang's FATFS?
See the example below. Thanks. if (f_mount(&FatFs, '''', 1) == FR_OK) { f_mkdir (''TEST''); count = 0; while(count < 200){ if(f_open(&fil, ''TEST/test.txt'', FA_OPEN_ALWAYS | FA_WRITE) != FR_OK){ break; } else{ sprintf(array,''This is file entry number: %d '',count); f_puts(array, &fil); if(f_close(&fil) != FR_OK){ break; } } count++; } f_mount(0, '''', 1); }
http://stackoverflow.com/questions/39560704/elm-changs-fatfs#
If I close a file and then reopen it, I cannot write more data to it after reopening it, but if i keep it open i can write as many lines as i want then close it when i am finish writing. See the example below. Thanks.
'',count); f_puts(array, &fil); if(f_close(&fil) != FR_OK){ break; } } count++; } f_mount(0, '''', 1);}
cleonb322
Posted on September 19, 2016 at 23:03
@clive
If I close a file and then reopen it, I cannot write more data to it after reopening it. Does anyone have this problem? if I execute the following code it will not save all the lines, it will save only the last line of data.
      f_mkdir (''TEST'');
      count = 0;
      while(count < 200){
              break;
          else{
              sprintf(array,''This is file entry number: %d\r\n'',count);
                  break;
          count++;
Posted on September 20, 2016 at 01:08, cleaned up messy forum transition 6-May-2023
Seek to the end of the file
// Incremental write test, appending to end-of-file
if (f_open(&fil, "LOG.TXT", FA_OPEN_ALWAYS | FA_WRITE) == FR_OK)
  UINT BytesWritten;
  const char string[] = "Another line gets added";
  f_lseek(&fil, fil.fsize); // newer perhaps f_size(&fil) macro?
  f_write(&fil, string, strlen(string), &BytesWritten);
  f_close(&fil);
Posted on October 23, 2017 at 12:08
Can you tell me how do you measure the writing speed to ur sd card???
Thanks & Regards
Sameena Shaikh
BYPASS is problematic on the F2/F4 implementations. ST want's you to use at least a DIV2 of the clock. However you can clock the SDIO peripheral from a 75 MHz PLL clock getting you 37.5 MHz on the bus. Problem then is that USB and CRYP don't work as wrong speed, and too fast.
