(sd)Disk explore
jspika
Posted on February 25, 2014 at 18:16
 I am trying to modify function static uint8_t Explore_Disk (char* path , uint8_t recu_level); from USB host example for writing our more than 1 subdirectory and for SD card.
I added :
            else if(recu_level == 3)
        LCD_DbgLog(''  |  |   |'');
and
            if(((fno.fattrib & AM_MASK) == AM_DIR)&&(recu_level == 2))
        Explore_Disk(fn, 3);
so now my code looks like that:
  FRESULT res;
  FILINFO fno;
  DIR dir;
  char *fn;
  //char tmp[14];
  char tmp[21];
  res = f_opendir(&dir, path);
  if (res == FR_OK) {
    while(((SD_Detect())==SD_PRESENT))
      res = f_readdir(&dir, &fno);
      if (res != FR_OK || fno.fname[0] == 0)
        break;
      if (fno.fname[0] == '.')
        continue;
      fn = fno.fname;
      strcpy(tmp, fn);
      line_idx++;
      if(line_idx > 14)
        line_idx = 0;
        LCD_SetTextColor(Green);
        LCD_DisplayStringLine( LCD_PIXEL_HEIGHT - 42, ''                                              '');
        LCD_DisplayStringLine( LCD_PIXEL_HEIGHT - 30, ''Press Key to continue...'');
        LCD_SetTextColor(LCD_LOG_DEFAULT_COLOR);
      if(recu_level == 1)
        LCD_DbgLog(''   |__'');
      else if(recu_level == 2)
        LCD_DbgLog(''   |   |__'');
            /******** ADDED*********/
      if((fno.fattrib & AM_MASK) == AM_DIR)
        strcat(tmp, ''\n'');
        LCD_UsrLog((void *)tmp);
      else
        LCD_DbgLog((void *)tmp);
      if(((fno.fattrib & AM_MASK) == AM_DIR)&&(recu_level == 1))
        Explore_Disk(fn, 2);
  return res;
The problem is,that it still doesnt write out more than 1 subdirectory and the recu_level is never 3, but I have really no clue why.
Does anyone has any idea why please?
Thank you.
Jan
Posted on February 25, 2014 at 19:06
What's the purpose here?
Do you have an adequate stack to permit this recursion?
jspika
Posted on February 25, 2014 at 19:22
There is no special purpose, I would like to just know, how does it work and why my modification doesnt work. And I have no special stack, I just hoped that this small modification could help.
