RTX Configuration via STM32CubeMX
jbeloso
Posted on September 26, 2016 at 11:56
I would like to use CubeMX and its grafical interface to generate code for my project in the Keil uvision IDE. I would like to use RTX RTOS too.
I only found this tutorial:
http://www.keil.com/pack/doc/STM32Cube/General/html/cubemx__r_t_x.html#cubemx_RTX_CubeMX
but this tutorial is for STM32F7, and I am working with Cortex M4 (STM32F4). I made this tutorial step by step but I have an error in the compilaton:
error: L6235E: More than one section matches selector - cannot all be FIRST/LAST.
Somebody knows what is the problem?? Any tutorial for this??
thank you very much.
slimen
Posted on September 26, 2016 at 14:52
Hello beloso.julio,
It seem you have a duplicate file names. Check your configuration setting.
More details in this
http://www.keil.com/support/docs/3751.htm
You may review this
http://www.st.com/content/ccc/resource/technical/document/user_manual/10/c5/1a/43/3a/70/43/7d/DM00104712.pdf/files/DM00104712.pdf/jcr:content/translations/en.DM00104712.pdf
about STM32CubeMx for STM32 configuration.
ingwmeier
Posted on September 26, 2016 at 16:20
we had a similar message, the cause was 2x inclusion of the startup assembly file in the project
