RCC_CSR resgister libary not found on my cube generated project stm32f103cb
TARHAN SAMAH
hello i try to read registers RCC_CSR with FlagStatusRCC_GetFlagStatus (uint8_t RCC_FLAG)
but my project generated by cubemx doesnt recognize this function ,
is there an option i didnt open on cube mx , or should i download a folder ,
because i couşdn find
STM32F10x Standard Peripherals Library 3.5.0 on my project
thanks
TARHAN SAMAH
thanks ,,
i got my registers :)
if(__HAL_RCC_GET_FLAG(RCC_FLAG_SFTRST))
//printf("\r\n software reset");
else if(__HAL_RCC_GET_FLAG(RCC_FLAG_PORRST))
//printf("\r\n power reset");
lcd_init();
else if(__HAL_RCC_GET_FLAG(RCC_FLAG_PINRST))
  //printf("\r\n pin reset");
else { /*printf("\r\n unknown reset ");*/  }
//// The flags must be cleared manually after use
__HAL_RCC_CLEAR_RESET_FLAGS();
it works good
Amel NASRI
Hi @TARHAN SAMAH​ ,
Standard Peripheral Library isn't supported by CubeMX; It is a different development approach than the Cube.
So, you cannot use it with CubeMX or merge code based on SPL and Cube on the same project.
-Amel
TARHAN SAMAH
thanks ,,
lcd_init();
it works good
