R/W to RTC backup registers
‎2016-08-26 7:39 PM
Hi.
I’m using an RTC example program from the CUBE F3
(STM32F3Nucleo)
download, and it work ok, except I cannot read or write to the RTC backup registers.
The example configures RTC as follows:
__HAL_RCC_PWR_CLK_ENABLE();
HAL_PWR_EnableBkUpAccess();
__HAL_RCC_RTC_ENABLE();
When I try to read and write to the backup registers, I cannot read back what I have previously written.
HAL_RTCEx_BKUPWrite(&RtcHandle, RTC_BKP_DR1, 0x32F2);
HAL_RTCEx_BKUPRead(&RtcHandle, RTC_BKP_DR1);
Even if I precede the read and or write with:
Any ideas?
Martin.
‎2016-08-28 8:49 PM
This might be happening because your RTC Oscillator Type and RTC Peripheral Clock might not be configured.Try to call the HAL_RTC_MspInit() and then perform RTC Read/Write.This should take care.Regards,Sunny- Mark as New
‎2016-09-05 5:52 PM
Hi Sunny.
I'm using the Nucleo board, and so far I cant seem to get the external 32khz clock to work. Most of the code I'm using has come from CUBE.
I changed to external clock as below, but it wont start.
PeriphClkInit.
RTCClockSelection
= RCC_RTCCLKSOURCE_LSE;
All my work so far has been with clock source set to RCC_RTCCLKSOURCE_LSI at 40khz.
Within the RTC_MspInit() function I call:
HAL_PWR_EnableBkUpAccess(); __HAL_RCC_RTC_ENABLE();and my sys clock config function is below: Sorry for the edits, blame ST.
void
SystemClock_Config(
void
RCC_OscInitTypeDef
RCC_OscInitStruct;
RCC_ClkInitTypeDef
RCC_ClkInitStruct;
RCC_PeriphCLKInitTypeDef
PeriphClkInit;
RCC_OscInitStruct.
OscillatorType
= RCC_OSCILLATORTYPE_LSI|RCC_OSCILLATORTYPE_HSE;
RCC_OscInitStruct.
HSEState
= RCC_HSE_BYPASS;
RCC_OscInitStruct.
LSIState
= RCC_LSI_ON;
RCC_OscInitStruct.
PLL
PLLState
= RCC_PLL_ON;
RCC_OscInitStruct.
PLL
PLLSource
= RCC_PLLSOURCE_HSE;
RCC_OscInitStruct.
PLL
PLLMUL
= RCC_PLL_MUL9;
RCC_OscInitStruct.
PLL
PREDIV
= RCC_PREDIV_DIV1;
if
(HAL_RCC_OscConfig(&RCC_OscInitStruct) !=
HAL_OK
Error_Handler();
RCC_ClkInitStruct.
ClockType
= RCC_CLOCKTYPE_HCLK | RCC_CLOCKTYPE_SYSCLK |
RCC_CLOCKTYPE_PCLK1 | RCC_CLOCKTYPE_PCLK2;
RCC_ClkInitStruct.
SYSCLKSource
= RCC_SYSCLKSOURCE_PLLCLK;
RCC_ClkInitStruct.
AHBCLKDivider
= RCC_SYSCLK_DIV1;
RCC_ClkInitStruct.
APB1CLKDivider
= RCC_HCLK_DIV2;
RCC_ClkInitStruct.
APB2CLKDivider
= RCC_HCLK_DIV1;
if
(HAL_RCC_ClockConfig(&RCC_ClkInitStruct, FLASH_LATENCY_2) !=
HAL_OK
Error_Handler();
PeriphClkInit.
PeriphClockSelection
= RCC_PERIPHCLK_USB | RCC_PERIPHCLK_USART1 |
RCC_PERIPHCLK_USART2 | RCC_PERIPHCLK_USART3 |
RCC_PERIPHCLK_RTC;
PeriphClkInit.
Usart1ClockSelection
= RCC_USART1CLKSOURCE_PCLK2;
PeriphClkInit.
Usart2ClockSelection
= RCC_USART2CLKSOURCE_PCLK1;
PeriphClkInit.
Usart3ClockSelection
= RCC_USART3CLKSOURCE_PCLK1;
PeriphClkInit.
RTCClockSelection
= RCC_RTCCLKSOURCE_LSI;
PeriphClkInit.
USBClockSelection
= RCC_USBCLKSOURCE_PLL_DIV1_5;
if
(HAL_RCCEx_PeriphCLKConfig(&PeriphClkInit) !=
HAL_OK
Error_Handler();
HAL_SYSTICK_Config(HAL_RCC_GetHCLKFreq() / 1000);
HAL_SYSTICK_CLKSourceConfig(SYSTICK_CLKSOURCE_HCLK);
/* SysTick_IRQn interrupt configuration */
HAL_NVIC_SetPriority(
SysTick_IRQn
, 0, 0);
static
void
MX_RTC_Init(
void
RTC_TimeTypeDef
sTime;
RTC_DateTypeDef
sDate;
RTC_AlarmTypeDef
sAlarm;
RTC_TamperTypeDef
sTamper;
/**Initialize RTC and set the Time and Date
hrtc.
Instance
= RTC;
hrtc.
Init
HourFormat
= RTC_HOURFORMAT_24;
hrtc.
Init
AsynchPrediv
= 127;
hrtc.
Init
SynchPrediv
= 255;
hrtc.
Init
OutPut
= RTC_OUTPUT_DISABLE;
hrtc.
Init
OutPutPolarity
= RTC_OUTPUT_POLARITY_HIGH;
hrtc.
Init
OutPutType
= RTC_OUTPUT_TYPE_OPENDRAIN;
if
(HAL_RTC_Init(&hrtc) !=
HAL_OK
Error_Handler();
sTime.
Hours
= 0x0;
sTime.
Minutes
= 0x0;
sTime.
Seconds
= 0x0;
sTime.
DayLightSaving
= RTC_DAYLIGHTSAVING_NONE;
sTime.
StoreOperation
= RTC_STOREOPERATION_RESET;
if
(HAL_RTC_SetTime(&hrtc, &sTime, RTC_FORMAT_BCD) !=
HAL_OK
Error_Handler();
sDate.
WeekDay
= RTC_WEEKDAY_MONDAY;
sDate.
Month
= RTC_MONTH_JANUARY;
sDate.
Date
= 0x1;
sDate.
Year
= 0x0;
if
(HAL_RTC_SetDate(&hrtc, &sDate, RTC_FORMAT_BCD) !=
HAL_OK
Error_Handler();
/**Enable the Alarm A
sAlarm.
AlarmTime
Hours
= 0x0;
sAlarm.
AlarmTime
Minutes
= 0x0;
sAlarm.
AlarmTime
Seconds
= 0x0;
sAlarm.
AlarmTime
SubSeconds
= 0x0;
sAlarm.
AlarmTime
DayLightSaving
sAlarm.
AlarmTime
StoreOperation
sAlarm.
AlarmMask
= RTC_ALARMMASK_NONE;
sAlarm.
AlarmSubSecondMask
= RTC_ALARMSUBSECONDMASK_ALL;
sAlarm.
AlarmDateWeekDaySel
= RTC_ALARMDATEWEEKDAYSEL_DATE;
sAlarm.
AlarmDateWeekDay
= 0x1;
sAlarm.
Alarm
= RTC_ALARM_A;
if
(HAL_RTC_SetAlarm(&hrtc, &sAlarm, RTC_FORMAT_BCD) !=
HAL_OK
Error_Handler();
/**Enable the Alarm B
sAlarm.
AlarmDateWeekDay
= 0x1;
sAlarm.
Alarm
= RTC_ALARM_B;
if
HAL_OK
Error_Handler();
/**Enable the WakeUp
if
(HAL_RTCEx_SetWakeUpTimer(&hrtc, 0, RTC_WAKEUPCLOCK_RTCCLK_DIV16) !=
HAL_OK
Error_Handler();
/**Enable the RTC Tamper 2
sTamper.
Tamper
= RTC_TAMPER_2;
sTamper.
Trigger
= RTC_TAMPERTRIGGER_RISINGEDGE;
sTamper.
Filter
= RTC_TAMPERFILTER_DISABLE;
sTamper.
SamplingFrequency
= RTC_TAMPERSAMPLINGFREQ_RTCCLK_DIV32768;
sTamper.
PrechargeDuration
= RTC_TAMPERPRECHARGEDURATION_1RTCCLK;
sTamper.
TamperPullUp
= RTC_TAMPER_PULLUP_ENABLE;
sTamper.
TimeStampOnTamperDetection
= RTC_TIMESTAMPONTAMPERDETECTION_ENABLE;
if
(HAL_RTCEx_SetTamper(&hrtc, &sTamper) !=
HAL_OK
Error_Handler();
