Question: '__init_array_end isn't defined'
myulgong
Posted on April 17, 2009 at 00:27
1 REPLY 1
myulgong
Posted on May 17, 2011 at 13:09
I tried to compile the STM32 example I downloaded at the winarm homepage ; everything else worked fine but then I got the following message:../ld.exe: main.elf: hidden symbol '__init_array_end' isn't defined.
I guess,as a newbie, that I have to supply some kind of symbol so that the loader can allocate actual memory. What do I have to add so that the
example application works properly?
Thanks.
