Programming full flash image over I2C
Bhautik
Is it possible to write the full image over I2C? If so, what is the recommended way to do this?
Bhautik
You don't mention a specific I2C, or context. If you write your own boot loader you have significantly more options/methods, but at the expense of code space
STM32 I2C bootloader protocol
https://www.st.com/resource/en/application_note/dm00072315-i2c-protocol-used-in-the-stm32-bootloader-stmicroelectronics.pdf
Bhautik
Thanks for the update
