program stuck in if(true) condition
montagnanigiovanni
Posted on September 22, 2014 at 20:36
hi all,
i work with stm32f4 and keil uv5
my program seems stuck in if condition
my code is
while(1)
            if(i==0)
                break;
and my debugger says that the program stops in the if despite i is zero!
have you experienced something like that?
do you know a possible explanation?
thank you
gio
Posted on September 22, 2014 at 21:19
Check optimization settings, and the volatility of variable.
There is often not the perceived one-to-one linear source to assembler relationship. Step the assembler view, and understand exactly what the flow really is, and look at or review the code generated.
