2008-07-22 09:33 PM
Problem with STM3210E-EVAL and Flash Programming
2011-05-17 03:40 AM
hallo,
can anybody help me. my problem is that the programming of the external flash on the stm3210e-eval is not possible. i tried to programm with DfuSe V2.2 but nothing happend. Than i found the flash loader demonstrator v1.1.1 but this tool is only able to detect the sram und the internal flash. can anybody help how to programm the external flash? thanks2011-05-17 03:40 AM
What do you mean that ''nothing happens'' when you try with Dfuse? Does the serial flash appear in the ''select target box'' ? On the B version of the Eval board you need to hold the ''key'' button down then hit reset. The chip will go into DFU mode that way. ettore2011-05-17 03:40 AM
it doesn't appear in the window. and i also tried to key button, nothing happend...
