Problem Uploading code to STM32F103ZCT7
krunal2411
Posted on February 16, 2015 at 12:59
Hello all,
I am having problem in updating the code to STM32F103ZCT7 using ST link V2.
I am getting the error as ''Can not connect to divice; Internal Command Error''
I am using three pins SWDIO, SWCLK, NRST.
I have cross check the connections using multimeter & all are OK.
I have not connected AVcc & AVss pins as well as Vbat pins i.e. they are floating, can this create any problem?
Please suggest.
Thanking You all.
#stm32f103zct7
Posted on February 16, 2015 at 14:23
Analogue supplies are not optional, they control the Power-On-Reset circuit.
krunal2411
Posted on February 17, 2015 at 04:20
Thanks Clive. I will power the analog part & will update here soon.
krunal2411
Posted on February 18, 2015 at 13:30
Thanks Clive.
Your suggestion worked for me.
