2014-12-22 11:21 AM
I've really tried to google but did not really find anything.
Are there any open source dev boards or just simple boards designed in KiCad and using the smaller or the larger LQFP packages?I have one for LQFP 100 but for some projects I want to use a cheaper chip and for some projects I am running low on IO pins.2015-01-23 5:36 AM
Well, here's the 176 board we've designed - I would appreciate if anyone can validate it.
http://svn.code.sf.net/p/rusefi/code/trunk/hardware/brain_board_176-pin/176-pin_board_PCB.pdf
http://svn.code.sf.net/p/rusefi/code/trunk/hardware/brain_board_176-pin/176-pin_board_Schematic.pdf
https://svn.code.sf.net/p/rusefi/code/trunk/hardware/brain_board_176-pin/
2015-02-06 2:15 AM
Hi andrey ! :)
you here too ?! :)) Y need use EAGLE coverted libs for KiCad file names : st-microelectronics.mod st-microelectronics.lib http://library.oshec.org/2015-02-06 3:40 AM
STM Libs file in attach
________________ Attachments : Eagle_Lib_For_KiCad.zip : https://st--c.eu10.content.force.com/sfc/dist/version/download/?oid=00Db0000000YtG6&ids=0680X000006I14a&d=%2Fa%2F0X0000000bhs%2FSwfd.UOpiJs_.YzWxPniEDdzSzGbVkSEBBuYnajtXuM&asPdf=falseWe’re moving the ST Community to a new platform to give you a better and more reliable community experience.
