Pb generating 2 PMW
‎2014-11-21 3:04 AM
‎2014-11-21 9:42 AM
Yeah, my bad, TIM15 needs the PWM Enable, TIM2 does not, on other STM32 architectures TIM1 & TIM8 are ''special''
/* Tim15 Main Output Enable */ TIM_CtrlPWMOutputs(TIM15, ENABLE); /* LIST6: TIM1, TIM8, TIM15, TIM16 and TIM17 */ #define IS_TIM_LIST6_PERIPH(PERIPH) (((PERIPH) == TIM1) || \ ((PERIPH) == TIM8) || \ ((PERIPH) == TIM15) || \ ((PERIPH) == TIM16) || \ ((PERIPH) == TIM17))Up vote any posts that you find helpful, it shows what's working..
‎2014-11-21 9:56 AM
Less blind, and having eaten breakfast... Stuck the scope on this one
// STM32 PMW @4MHz (PA9) and @1MHz (PA3) STM32F3-Discovery - sourcer32@gmail.com
#include ''stm32f3_discovery.h''
#include ''stm32f30x.h''
static void TIM_Config(void)
TIM_OCInitTypeDef TIM_OCInitStructure;
uint16_t TimerPeriod = 0;
uint16_t ChannelPulse = 0;
/* GPIOA & GPIOB Clocks enable */
RCC_AHBPeriphClockCmd(RCC_AHBPeriph_GPIOA, ENABLE);
/* GPIOA & GPIOB Configuration: Channel 3 (TIM2) and Channel 2 (TIM15) as alternate function push-pull */
GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_UP ;
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_9 | GPIO_Pin_3; // TIM2_CH3 (PA9), TIM15_CH2 (PA3)
GPIO_PinAFConfig(GPIOA, GPIO_PinSource9, GPIO_AF_10); // TIM2 PA9 AF10
GPIO_PinAFConfig(GPIOA, GPIO_PinSource3, GPIO_AF_9); // TIM15 PA3 AF9
/* Compute the value to be set in ARR regiter to generate signal frequency at 1MHz */
TimerPeriod = (SystemCoreClock / 1000000);
/* Compute CCR value to generate a duty cycle at 50% for channel */
ChannelPulse = (uint16_t) (((uint32_t) 5 * TimerPeriod) / 10);
/* Tim15 clock enable */
RCC_APB2PeriphClockCmd(RCC_APB2Periph_TIM15, ENABLE);
/* Time Base configuration */
TIM_TimeBaseStructure.TIM_Period = TimerPeriod - 1;
TIM_TimeBaseStructure.TIM_RepetitionCounter = 0;
TIM_TimeBaseInit(TIM15, &TIM_TimeBaseStructure);
/* Channel Configuration in PWM mode - fully qualify TIM15 is special */
TIM_OCInitStructure.TIM_OCMode = TIM_OCMode_PWM2;
TIM_OCInitStructure.TIM_Pulse = ChannelPulse;
TIM_OCInitStructure.TIM_OutputState = TIM_OutputState_Enable; // Want the Positive
TIM_OCInitStructure.TIM_OutputNState = TIM_OutputNState_Disable; // not the negative
TIM_OCInitStructure.TIM_OCPolarity = TIM_OCPolarity_High;
TIM_OCInitStructure.TIM_OCNPolarity = TIM_OCPolarity_High;
TIM_OCInitStructure.TIM_OCIdleState = TIM_OCIdleState_Reset;
TIM_OCInitStructure.TIM_OCNIdleState = TIM_OCNIdleState_Reset;
TIM_OC2Init(TIM15, &TIM_OCInitStructure); // TIM15_CH2 - PA3
/* Tim15 counter enable */
TIM_Cmd(TIM15, ENABLE);
/* Tim15 Main Output Enable - TIM15 is special on STM32F3 */
/* Compute the value to be set in ARR regiter to generate signal frequency at 4MHz */
TimerPeriod = (SystemCoreClock / 4000000);
/* Tim2 clock enable */
RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM2 , ENABLE);
TIM_TimeBaseInit(TIM2, &TIM_TimeBaseStructure);
/* Channel Configuration in PWM mode */
TIM_OCInitStructure.TIM_OCIdleState = TIM_OCIdleState_Set;
TIM_OC3Init(TIM2, &TIM_OCInitStructure); // TIM2_CH3 - PA9
/* Tim2 Counter Enable */
TIM_Cmd(TIM2, ENABLE);
int main(void)
/*!< At this stage the microcontroller clock setting is already configured,
this is done through SystemInit() function which is called from startup
file (startup_stm32f30x.s) before to branch to application main.
To reconfigure the default setting of SystemInit() function, refer to
system_stm32f30x.c file
/* TIM Configuration */
TIM_Config();
/* Infinite loop */
while (1);
#ifdef USE_FULL_ASSERT
* @retval None
ex: printf(''Wrong parameters value: file %s on line %d
'', file, line) */
/* Infinite loop */
while (1)
#endif
‎2014-11-21 10:19 AM
Scope verdict: Tim15_Ch2 still dead!
‎2014-11-21 10:27 AM
Scope probe check and working fine....
________________ Attachments : Screen_2014-11-21_07-26-27.jpeg : https://st--c.eu10.content.force.com/sfc/dist/version/download/?oid=00Db0000000YtG6&ids=0680X000006I14R&d=%2Fa%2F0X0000000bi0%2FJne6cqueKuo_MA9TgvpA.yz5HvKTm1Jorm2p0Qxoafc&asPdf=false- Mark as New
‎2014-11-21 10:32 AM
Sorry my scope isn't that fancy, but definitely getting 1 MHz on PA3 of an STM32F3-DISCO, don't know what PA3 is wired too on a NUCLEO, USART output from ST-LINK?
‎2014-11-21 10:42 AM
Nucleo Scheme seems you're right...USART
________________ Attachments : MB1136.pdf : https://st--c.eu10.content.force.com/sfc/dist/version/download/?oid=00Db0000000YtG6&ids=0680X000006I14z&d=%2Fa%2F0X0000000bi1%2FEduQJZTz6YufThU84vKo9y22eZVjIjSr51VEWLWkq3E&asPdf=false- Mark as New
‎2014-11-21 10:55 AM
PA2 should be viable, it's not clashing with an output.
// STM32 PMW @4MHz (PA9) and @1MHz (PA2) STM32F3-Discovery - sourcer32@gmail.com
/* GPIOA & GPIOB Configuration: Channel 3 (TIM2) and Channel 1 (TIM15) as alternate function push-pull */
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_9 | GPIO_Pin_2; // TIM2_CH3 (PA9), TIM15_CH1 (PA2)
GPIO_PinAFConfig(GPIOA, GPIO_PinSource2, GPIO_AF_9); // TIM15 PA2 AF9
TIM_OC1Init(TIM15, &TIM_OCInitStructure); // TIM15_CH1 - PA2
int main(void)
TIM_Config();
/* Infinite loop */
while (1);
* @retval None
'', file, line) */
/* Infinite loop */
while (1)
#endif
‎2014-11-21 11:07 AM
Mad...Still dead!
So I'll try with TIM1_CH1. At first I didn't want to use it, being a powerful one....but it's friday....so....No way!- Mark as New
‎2014-11-21 11:20 AM
I should do something wrong as I didn't get any PMW either with Timer15, or even now Timer1. Scope is ok. Probe also. I've checked probe channel 2.
So it must be something obvious....- Mark as New
‎2014-11-21 11:23 AM
My new code program with Timer 1 CH1 and what the scope gave me:
// STM32 PMW @4MHz (PA9) and @1MHz (PA2) /**************************************************************************************/ #include ''stm32f30x.h'' /**************************************************************************************/ static void TIM_Config(void) { GPIO_InitTypeDef GPIO_InitStructure; TIM_TimeBaseInitTypeDef TIM_TimeBaseStructure; TIM_OCInitTypeDef TIM_OCInitStructure; uint16_t TimerPeriod = 0; uint16_t ChannelPulse = 0; /* GPIOA & GPIOC Clocks enable */ RCC_AHBPeriphClockCmd(RCC_AHBPeriph_GPIOA | RCC_AHBPeriph_GPIOC, ENABLE); /* GPIOA & GPIOC Configuration: Channel 3 (TIM2) and Channel 1 (TIM1) as alternate function push-pull */ GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF; GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz; GPIO_InitStructure.GPIO_OType = GPIO_OType_PP; GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_UP ; GPIO_InitStructure.GPIO_Pin = GPIO_Pin_9 ; // TIM2_CH3 (PA9) GPIO_Init(GPIOA, &GPIO_InitStructure); GPIO_PinAFConfig(GPIOA, GPIO_PinSource9, GPIO_AF_10); // TIM2 PA9 AF10 GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0 ; // TIM1_CH1 (PC0) GPIO_Init(GPIOC, &GPIO_InitStructure); GPIO_PinAFConfig(GPIOC, GPIO_PinSource2, GPIO_AF_2); // TIM1 PC0 AF2 /* Compute the value to be set in ARR regiter to generate signal frequency at 1MHz */ TimerPeriod = (SystemCoreClock / 1000000); /* Compute CCR value to generate a duty cycle at 50% for channel */ ChannelPulse = (uint16_t) (((uint32_t) 5 * TimerPeriod) / 10); /* Tim15 clock enable */ RCC_APB2PeriphClockCmd(RCC_APB2Periph_TIM1, ENABLE); /* Time Base configuration */ TIM_TimeBaseStructure.TIM_Prescaler = 0; TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up; TIM_TimeBaseStructure.TIM_Period = TimerPeriod - 1; TIM_TimeBaseStructure.TIM_ClockDivision = 0; TIM_TimeBaseStructure.TIM_RepetitionCounter = 0; TIM_TimeBaseInit(TIM1, &TIM_TimeBaseStructure); /* Channel Configuration in PWM mode - */ TIM_OCInitStructure.TIM_OCMode = TIM_OCMode_PWM2; TIM_OCInitStructure.TIM_Pulse = ChannelPulse; TIM_OCInitStructure.TIM_OutputState = TIM_OutputState_Enable; // Want the Positive TIM_OCInitStructure.TIM_OutputNState = TIM_OutputNState_Disable; // not the negative TIM_OCInitStructure.TIM_OCPolarity = TIM_OCPolarity_High; TIM_OCInitStructure.TIM_OCNPolarity = TIM_OCPolarity_High; TIM_OCInitStructure.TIM_OCIdleState = TIM_OCIdleState_Reset; TIM_OCInitStructure.TIM_OCNIdleState = TIM_OCNIdleState_Reset; TIM_OC1Init(TIM1, &TIM_OCInitStructure); // TIM1_CH1 - PC0 /* Tim15 counter enable */ TIM_Cmd(TIM1, ENABLE); /*----------------------------------------------------------------------- */ /* Compute the value to be set in ARR regiter to generate signal frequency at 4MHz */ TimerPeriod = (SystemCoreClock / 4000000); /* Compute CCR value to generate a duty cycle at 50% for channel */ ChannelPulse = (uint16_t) (((uint32_t) 5 * TimerPeriod) / 10); /* Tim2 clock enable */ RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM2 , ENABLE); /* Time Base configuration */ TIM_TimeBaseStructure.TIM_Prescaler = 0; TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up; TIM_TimeBaseStructure.TIM_Period = TimerPeriod - 1; TIM_TimeBaseStructure.TIM_ClockDivision = 0; TIM_TimeBaseStructure.TIM_RepetitionCounter = 0; TIM_TimeBaseInit(TIM2, &TIM_TimeBaseStructure); /* Channel Configuration in PWM mode */ TIM_OCInitStructure.TIM_OCMode = TIM_OCMode_PWM2; TIM_OCInitStructure.TIM_Pulse = ChannelPulse; TIM_OCInitStructure.TIM_OutputState = TIM_OutputState_Enable; TIM_OCInitStructure.TIM_OCPolarity = TIM_OCPolarity_High; TIM_OCInitStructure.TIM_OCIdleState = TIM_OCIdleState_Set; TIM_OC3Init(TIM2, &TIM_OCInitStructure); // TIM2_CH3 - PA9 /* Tim2 Counter Enable */ TIM_Cmd(TIM2, ENABLE); } /**************************************************************************************/ int main(void) { /*!< At this stage the microcontroller clock setting is already configured, this is done through SystemInit() function which is called from startup file (startup_stm32f30x.s) before to branch to application main. To reconfigure the default setting of SystemInit() function, refer to system_stm32f30x.c file */ /* TIM Configuration */ TIM_Config(); /* Infinite loop */ while (1); } /**************************************************************************************/ #ifdef USE_FULL_ASSERT /** * @brief Reports the name of the source file and the source line number * where the assert_param error has occurred. * @param file: pointer to the source file name * @param line: assert_param error line source number * @retval None */ void assert_failed(uint8_t* file, uint32_t line) { /* User can add his own implementation to report the file name and line number, ex: printf(''Wrong parameters value: file %s on line %d\r\n'', file, line) */ /* Infinite loop */ while (1) { } } #endif ________________ Attachments : Screen_2014-11-21_08-22-44.jpeg : https://st--c.eu10.content.force.com/sfc/dist/version/download/?oid=00Db0000000YtG6&ids=0680X000006I14k&d=%2Fa%2F0X0000000bhy%2F.0fXpGd0u86TaaaGCBmJjorPSurDQKiav92Bpymdo6Y&asPdf=false
