Packing bits with byte (difference between f103 and f105)
aoleon
Posted on April 13, 2010 at 17:27
2 REPLIES 2
Posted on May 17, 2011 at 13:47
Perhaps your problem is one of initialization. Unless you explicitly clear that data structure it will contain random data except for the bits you set.
setup_a_t setup_a;
setup_a.value = 0;
setup_a.bits.a = (uint8_t) 3;
SPI_write_reg (REG, setup_a.value);
-Clive
aoleon
Initializing the variable works!
Thanks!
Alex
